More on Altitude issues
Status
Not open for further replies.
Ok
Sounds like a DJI Boy just flat deny.
Have you ever tried it?
Based on your obvious position you will just deny it anyway.
Like I said before I’ve owned and flow over 100 DJI drones of my own personal money.
I’ve got 35 registered at DJI right now as I type.
I also have 2 Cine combos and a air 2s with RC Pro controllers.
Do you?
Ok you got a lot of DJI Drones but you still want to continue.
Maybe you just want to be argumentative. Members here know
the drill. Now you will also. I would quit while I was ahead and not
try and continue in another’s thread.
Last I will say here.
Reactions: db4476
And now with my #1 M3Cine. Notice after coming back for a hover the altitude is off by 5-7’ and the VPS is showing 3.0’ exactly how high I was. 9F5D1FBF-A71E-4DF9-B8AB-087E5524C9E4.jpegD81352A3-C001-4384-8C4E-8367396101C9.jpeg24B503E4-03B1-46D4-845A-4BDE6BAE746C.jpeg
You can see the Red VPS display lower center being partially covered by the screen record display. It is dead nuts accurate. However like every single one of my DJI craft have done this. It’s been much worse at times out in the hills. When I go deeper.
5-7 feet !!
Have you read any of what I've written?
That's common and completely normal.
If you fly in a real plane like a Cessna, you'd notice the same thing (if the altimeter even registered such small increments).
ps flying at negative altitude makes no difference.
Yes it appears to.
That is the only scenario it happens in.
Otherwise prove it to us.
5-7’ will matter in a court of law.
Yes it appears to.
The differences you've observed in indicated height are due to small changes in your local air pressure over the duration of a flight.
That's all.
It's common and normal and happens to everyone.
Your indicated height cannot be relied on to be accurate to the last foot.
Just like GPS can't be that accurate either.
If you want to make outrageous claims, it's up to you to substantiate them.
So I am correct. They are inaccurate.
VPs is very accurate in my measurements.
Correct?
No
Trolling?
Yes
The issue was explained to you in the first response to your claim and in many of the posts following, but you ignored them.
And despite your uninformed ideas, small differences in indicated height aren't any more likely after flying below the launch point than above.
It's also hard to imagine any scenario where this would ever make any difference in a court of law.
But please don't bother to challenge that because it would be just as pointless as all the posts you've made in this thread.
And we have left the OP behind and this over.
Guys you want to continue start a thread on this but
i don’t have time to babysit this And am not.
CLOSED​
Reactions: db4476 and sar104
Status
DanCan
