My hard case
ToddR
I can see the need for a case. Well actually I'm thinking two different cases. I arranged my own fly more combo if you will. Best Buy sale offered a $100.00 gift card. My initial desire was to have a sling backpack type case. Something I would be able to travel or adventure with. Unfortunatly they didnt really have anything in a back pack style that even closely appealed to me. I chose this hard case instead. I can honestly say I like it. I do need to modify it slightly. As you can see the free filter case does not have a spot. It closes fine when laid on top of the charging assesories. I'm thinking I might cut out a little padding just above this on the top. That should hold the case in place and out of the way. Anyway just thought I would share.
I've had both a hard case and backpack for my Mavic Pro. I use the Lowepro Slingshot Edge 150 most as it's convenient and hike with my Mavic quite a bit, it's nice having free hands when hiking.
Reactions: ToddR
I've got a Fly More bag, a semi-hard case (foam inserts with non-rigid plastic shell in backpack form) and my most commonly used bag is a Manfrotto Small Advanced Tri Camera backpack which has space for drone, batteries, controller, bracket, tablet, cables, filters, cards, and even my WD MyPassport Wireless Pro and a charger if needed. It also has external loops for tripod attachment that can hold coats, tarps, whatever.
The reason I use the Manfrotto so often is because it's incredibly comfortable to wear, even with the added weight of portable drive/charger it's not bulky nor does it make my shoulders/back tired.
Reactions: ToddR
00B3rin
