- Joined
- Jan 10, 2019
- Messages
- 207
- Reactions
- 216
So nobody is interested in the number of safe landings, only the mishaps. The most important suggestion I can offer especially to new flyers (assuming you've read the manual AND spend a good amount of time watching the many excellent videos to help you understand your drone), is to understand and practice the RTH function. And I don't mean using the precise take-off and RTH function which I was very familiar with. I mean, flying your drone in safe quarters and TEST the RTH function by:
1. letting your battery setting return the drone
2. disconnecting your controller to see if the RTH works
3. understanding you can still control your flight without the GO4 app
After 3 months of blissful flying in Kaui, (many times over the ocean) I lost my drone a month ago (over water)...never to be recovered. On the upside DJI did replace my Mavic Air with a NEW drone (not refurbished) within 2 weeks of their tech team looking at my logs. I was asked that it not be refurbished but didn't push too hard as I was fortunate to have them fully set me up with a new craft. I was aided immensely by a very experienced operator in this forum who knew how to interpret the Event Stream which pointed to some serious errors (which I still don't understand). A mere 100 M and a "safe" altitude above the water, I first lost the video stream with only 3 minutes into my flight and lost my signal. I simply don't recall if I initiated the RTH function although I am led to understand that the RTH function will initiate after a 3 second signal loss. Mine did not return home! My sense is that we can pretty comfortable when everything is going right, but how will we react in a panic situation (signal loss).
Upon receiving my new MA and new battery from DJI (I was out the SIM card and an ND filter), I had to reset all the parameters of my bird and camera settings. Began flying very cautiously over the past week to determine that the GO4 update and the firmware updates are properly functioning. I have had no issues to date (about 30 flights).
Make your own landing pad and keep the dirt, dust etc out of your gimbal mechanism. The ones you can buy work best if the ground allows you to push in the pegs....doesn't work well on rock. Make your own...you'll need some naugahyde or similar substantial material, two small pieces of heavy tubing, ShoeGoo (or a similar strong flexible adhesive) and a DIY pattern. I just made a second one to keep in my quad when I looking for adventure. The pad will nicely roll up. Happy Flying.
