Howdy mark reah, what system are you using (iOS or Android?) What type of memory card? How often / at what time does it happen?my mavic keeps saying no signal and stops filming still flies fine with controller
hi using android sandisk 64g sd card could it be the usb leadHowdy mark reah, what system are you using (iOS or Android?) What type of memory card? How often / at what time does it happen?
will try to put a usb in the bottom plug instead of using the one on the side cheersSounds like a dodgy USB cable there mate
cheers pal nice oneI'd recommend that every time. Not had a single disconnect since I started using an Anker cable in the bottom / rear USB port
So, wait a minute, you took a jet ski out to your hovering bird & didn't take the RC with you?
I think you are quite lucky to get your bird back, lucky man!
I just purchased the mavic pro and am having this same issue. I need clarification.I'd recommend that every time. Not had a single disconnect since I started using an Anker cable in the bottom / rear USB port
Anker is just a brand of cable.I just purchased the mavic pro and am having this same issue. I need clarification.
-What is an anchor cable? Sounds like connect thru regular usb to phone. I'm using iPhone.
-How to use?
-Where to purchase?
Also, on this same issue I can connect to drone, leave connected without taking off and it will lose signals.
Thanks. Just ordered off eBay.Anker is just a brand of cable.
Basically you want to use the full sized usb on bottom of controller and a standard genuine lightening cable or MFi certified one.
