I need some example Mavic Mini .DATs that are created by the DJI FLY App. They will be used in the reverse engineering effort required to include the MM in CsvView/DatCon. I was hoping to see some in this forum but have only seen one so far. mavic mini crashed without a reason Here are the instructions to retrieve a tablet .DAT from the Go 4 App - apparently they can be used to retrieve .DATs from the Fly App as well.
Retrieving a V3.DAT from the tablet
If possible, the corresponding .txt would also help.
It would also help if someone could create a .DAT by 1) starting the Fly App and waiting until it's finished it's startup and then 2) powering up the MM and let it sit for 2 minutes without doing a motor start.
A more involved test .DAT is needed where
0) remove the props from the MM
1) start the Fly App
2) power up the MM
3) start the motors
4) grab the right front motor to slow it down for a second or so, then the left front, then the left back and finally the right back.
@WooZie
2) power up the MM
3) start the motors
@WooZie
