New guy
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching
and stay safe.. 👍
Welcome to the forum! :)
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. As dirkclod said, search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Thanks! Yeah, lots to search here.
Reactions: Skywatcher2001
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Welcome from the Hampton Roads area of Virginia. I too am a Mini 2 Flyer and know the excitement of flight. So, if I may offer some advice.
Plug in your phone/tablet into your controller, turn on the Controller and DJI Fly App (if it does not start on its own…). Open the front legs, open the back legs of your drone, then remove the Gimbal Cover.
The Gimbal is the most delicate item and banging or bumping can damage it. I also fastened a short "remove before flight" ribbon to the cover so it's more noticeable and I do not forget to remove it…
Place the drone down so it can acquire its senses and finish its self-test (collect satellites, etc…).
Check your battery status (Phone, Drone, and controller), check the signal strength, by now the controller should have reported it updated the Home Point.
Lift off, 4-5 feet (1-1/2 meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your controller will probably report again, Home point Updated.
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or old tree, you are flying over and in your excitement, you'll fly the drone long past it Low Battery point and when it engages RTH and lands in the pond or in a tree, it will be all on you…
Now go have fun, learn to fly the drone by sight before you take it too out far, depending on the video feed, FPV.
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby;" also read over the user's manual… the link is below in case you did not get one…
Happy Droning
sam452
