Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends. Also, check out some of the recent New Pilots who have checked in, severa are also from the UK.
mavicpilots.com
That is a GREAT Photo, thanks for sharing.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
According to CAA, drones are allowed in the UK, subject to CAA regulations. Read on for more details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
