Not Stable in flight
David Babcock
River Falls, WI
I was flying a set of waypoints and the drone seemed to have a huge problem staying level. Has anyone had this happen? I have recalibrated the gimbal and the IMU.
thanks for any help.
Is this with a MA2 ?
This is due to drone pitching down as it moves towards next way point but camera facing left.
I have 30 flights prior to this where the drone did not exhibit this behavior. I am monitoring two impoundments here in town using a set of waypoints. I fly the exact same pattern every week. This is new behavior for the drone. Does the drone have a gyroscope that helps maintain level flight? Could it be failing?
I have re downloaded the firmware - recalibrate the senors - calibrate the gimbal - I still can not get a stable flight using waypoints.
here is the flight log if anyone can see something helpful.
  • DJIFlightRecord_2020-08-24_[08-36-46].txt
InspectorTom
