Obstacle Avoidance bug????
Donnie Frank
Albuquerque, N.M.
Hey doods!
So flying last night about 7:00 over a wilderness area about 900' AGL, while on it's way home, my Mavic stops in its tracks and utters the "Obstacle Avoidance reset" warning. Hmmm.... So I push the stick forward, and about 100' later, she does it again. So I tried to turn off Obstacle Avoidance and it won't disable....hmmmm... I eventually got the bird home, but lesson learned. I personally think that Obstacle Avoidance just gives us a false sense of security. Call me nuts, but I avoid objects all on my own...LOL....
Has anyone else experienced this bug?
Disclaimer: I launched @ 9,000' elevation within 3,000' of a 10,000' mountain peak. So, technically, I was flying 100' BGL.
You can also switch into Sport mode, as that will disable obstacle avoidance as well.
Reactions: Dragonfly
Curious thought, but perhaps turning off the obstacle avoidance will spare some battery?
I’d try to just reset the App the RC and the aircraft. Safe Flights.
Reactions: NinjaNut and Budd61
I usually keep mine off except when trying to get close shots of something or when i'm coming into land.
Interesting. I don't put much faith in that avoidance crap anyway. Shutting it OFF.
I flip mine on and off depending on whats going on.
In this case it saved me.
At the 12 sec mark you can see my van pull up. Then I still couldent find it so I tried taking it up to see where it was,but didn't have enough battery
That didn't seem to work. That was the first thing I did. In fact, most of that flight was done in sport mode. If I recall, the error message was "Obstacle Avoidance reset." Reset? Hmmmm...
If that message was recorded in the flight log, you'll be able to see it if you upload your TXT flight log here (and whether or not your were flying in Sport mode at that time).
Reactions: Vladimirni
Do you shut the ones on the bottom off also?
i do because i feel i dont really need obstacle avoidance,i had an issue last year that spooked me and had read where a RTH obstacle avoidance kept the drone from returning home because it hovered until the battery went dead,i recalibrated on the cpu via DJI assistant because mine were constantly initiating and it seemed to help but i just keep them off,the only time i use them for safety is when in a rotating active track maneuver
but always off when flying manually
Good call. I've downloaded and examined the Flight Records for that flight. Despite an amazing amount of information being recorded every .1 seconds, the "Messages" field doesn't show the error message I received several times. Disappointing.
It DOES show that about half the flight was in Sport mode. But seems the last 2 minutes was flown in P-GPS mode. So, perhaps, a switch to "Sport mode" might have circumvented the problem.
destinyrett
