Occasional yellow status light but no disconnect light
mobalized
It has happened a few times now where I will get a yellow status light on the rear of the Mavic mid flight. It goes back to green very quickly, and does not display any messages in the app or on the controller. I wouldn't describe the light as "rapid" but it is hard to tell because it happens so quickly and then goes back to green. I had one such flight today, and I've looked at the txt log file and not found any indicator of an issue. I receive no disconnect message or anything of the sort. Does anyone have any ideas on this?
dat log file: http://s000.tinyupload.com/?file_id=57054168825552861757
txt log file: http://s000.tinyupload.com/?file_id=58921791983137613263
I have found that if you are flying in low light conditions (dusk/dawn) you may get 3 yellow flashes followed by the normal green ones. Turning off OA will get rid of the light but it is just letting you know that OA may not work due to light.
LeoleoLeo
