Passed the FAA Part 107 exam!
DJ Wes
Springdale, AR, USA
Site
www.litchiutilities.com
I passed the "Part 107" (sUAG) exam this week with a 98% (one wrong). Woohoo!
I had enrolled in the Pilot Institute Part 107 course. I went through the materials three times. Greg and the PI team have done a really good job of putting the "Part 107" materials together. The course materials are divided into around 10 sections (Regulations, OOP, Sectional Charts, Weather, etc.). Each section is further divided into short lessons. Once I felt confident that I knew all of the material, I went ahead and scheduled the exam.
The bulk of the questions on the exam involved reading sectional charts with a few questions on METARs, NOTAMs, etc. I was comfortable with that. There were a handful of questions on the exam which weren't explicitly covered in the course (which was expected). However, if you thought about the question and considered all of the answers, you could usually figure out the correct answer.
One of the questions (the first one on my exam) was about landing a fixed-wing aircraft at night. I don't remember the exact wording, but it was something like this:
Question: You are performing a night landing but coming in too low and too slow. What do you do?
a) Abort the landing and execute a go-around.
b) Apply more throttle.
c) This is normal. Proceed to land.
I got this one right. I'll let you figure out the answer.
Congratulations DJ Wes. 👍
I'm guessing A. 🤔
Technically speaking, I think the answer would be "B then A"
Though, thinking about it, the possible answers are a little too vague.
The correct answer (that makes sense to me) would be "apply more throttle and level out enough to see if a regular landing is still feasible. If so, proceed to land. If not, increase altitude and execute a go-around.
For those of you who chose "a" as the answer, you are correct.
While "b" seems to be a reasonable choice, since "night" was included in the question and since safety is paramount in the airline industry, a "go-around" was the correct choice.
Now, for the only question on the exam that I got wrong. Again, I don't remember the exact wording, but it went something like this:
Question: You have an sUAV that satisfies multiple "Operations Over People" (OOP) categories. How does the remote pilot in command switch the sUAV between those categories?
a) You cannot switch an sUAV between multiple OOP categories.
b) Categories can only be changed when the sUAV is on the ground.
c) Categories can be changed as long as it cannot be done inadvertently.
Again, since safety is paramount, I chose "b". You can find the correct answer by looking up:
§107.150 Variable mode and variable configuration of small unmanned aircraft systems.​
Isnt there less lift at night? Id probly go around and feel it out
Though the simple answer might just be more throttle
Less light at night? Air Molecules don't know "night from day". In actuality, if the NIGHT air is cooler (and it usually is) you'll get MORE lift at night but that's assuming all other factors are the same.
Cool Air - More Lift
Warm Air - Less Lift
Reactions: Hauptmann
Air is colder at 30,000 feet.
Yes, air is usually colder at 30,000 feet when compared to the temperature of air at sea level, but air isn't colder at 30,000 feet when compared with air temperature at 45,000 feet. Everything is relative.
Congratulations Wes on your successful completion of your part 107 exam!
Chris
Reactions: DJ Wes
Congratulations!
Reactions: DJ Wes and sarahb
Congratulations 🎈🍾🎉🎊
Reactions: DJ Wes
elitewikipublishers
