POI vs Circle.
Cilo
Italy
Hello,
New member of Mavic Pilots.
I have a question I couldn't find online.
What isbthe real difference between using POI vs Quickshot (circle). They both go around a select area.
But what's the difference?
poi you just pick the poi, circle you pick the poi then set the distance between the poi and the drone
Reactions: Cilo
You can also set the direction the AC faces in a POI as it circles.
Reactions: Cilo
poi just uses the current distance , and circle you set the distance
Try asking You Tube Search box- I found the videos by Jeff Greene very good. Here are a few to start off with.
Reactions: Thomas B
Drsmurph
