Is there a tested and proven portable battery pack that can be used to fully charge a SC while out in the middle of nowhere? Or operate on it directly?
Ideally I am looking for something with a capacity above 20,000 mAh.
I suspect the OP is asking about a USB Power Brick that supports Quick Charging (QC3) so that he can recharge the Smart Controller when out and about in the field as well as during flights. Charging while in flight is supported, I don’t have a Power brick in mind that supports USB Quick Charging (QC3).
Note - I doubt he's asking about Mavic Air compatible devices as he indicated Smart Charger (SC)...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
