Get close enough and they can affect the compass but at 20 ft from your low voltage domestic supply lines, you'll be fine.I would like to video my house but I have power lines across the front of my street in front of my house I would be about 20 feet away
i believe it would depend on the amount of power lines i’ve launched from an area where the lines were l-shaped and had interferencepower lines ? providing you dont run into them
do they effect anything while in flight
Electricity can jump 2/3 Mtr under the right conditions from power lines generally best to give them as much room as possible.
But it will only jump if there is a ground or neutral phase close enough.Electricity can jump 2/3 Mtr under the right conditions from power lines generally best to give them as much room as possible.
Not strictly true - since the power lines are three phase AC, capacitive loading of the aircraft can cause discharge/arcing.That's true, but it will only jump to a conducting pathway. It won't jump to an airborne object.
A hypothetical interference from a 500kv line into compass and other electronics. Not highly probable, but possible. Like flying in the working microwave.The capacitance of the aircraft is negligibly small, so I don't understand what you are envisaging here.
