problem with DJI MAVIC PRO display
MariaEvri
hello, I have the DJI Mavic pro
Yesterday I started having this problem
the screen will not focus when I tap it, and it keeps flickering
I tried three different locations, twi different mobiles and two different cables
What could be wrong?
Reactions: Cafguy
There are a few things you should do really.
1. Check your settings carefully
2. Clean the lens.
3. Make sure the firmware is up to date.
4. Make sure your lighting is sufficient.
5. Calibrate.
6. Python Calibrate
7. Factory Reset.
8. If none of the above work you have a faulty gimbal or camera.
mini3user
