Won't a GPS tracker (no matter how small) affect flight characteristics and, specially, compass calibration and performance?
Thank you for any replies.
MK
MK
A small GPS tracker such as the Marco Polo or Trackimo would have an extremely minimal effect on flight characteristics. 1.4 ounces is practically negligible. As @Telescott mentioned, your main problem is going to be finding the best place to mount. You've got some space on the very rear of the Mavic. I would avoid mounting on the top due to concerns with compass interference.
GPS data will only be transmitted to the Mavic remote controller while the downlink (OcuSync connection) is up. If the downlink signal is lost, all you'll have is the last location sent to the remote controller. Depending on what caused the downlink to disconnect, your Mavic could fly far away from the last recorded location before it makes it to its final resting place.I'm pretty sure that the built in GPS transmits to the RC and can be used that way
Considering it usually takes some type of impact to dislodge the battery, the Mavic should be close to the last recorded GPS position if the battery dislodges.Not sure what happens if it crashes and the battery comes out
So, I already got one of these Genuine GPS Tracker Magnetic Car Vehicle Personal Tracking Device 102-NANO TK102 | eBay
It works great and I hope that, at 30 grams, it won't be a problem.
Now all I need is the actual drone
...but even that has come closer to being a reality...
Initially, I was planning to get mine about February/March, next year...But, reading about all the delays in production and distribution, I was faced with a conundrum, as I wasn't able to tell which ordering time frame would guarantee that.
So, this Saturday I placed an order with a national supplier but, since ours is such a small market, sometimes surprising things happen as distribution channels secure small but firm allotments for our country.
It may very well turn out that I get the mail to go and pick it up much sooner than anticipated.
...which will be OK. One of the reasons that made me want to wait a little bit was any possible negative feedback from early users and that, as far as I can tell, is falling well within reasonable boundaries.
FK
Loz,
This is how I'm mounting my Marco Polo for now using the 10lb command strips. I'll figure out a better method after I'm sure my bird is solid. It has been noted that it is necessary to do a new compass cal anytime you install or remove the tracker.
Jerry
View attachment 2595 View attachment 2597 View attachment 2598
Actually, that is probably the best place to mount it. From what I remember there is one compass in the nose and the other at the back of the Mavic.A small GPS tracker such as the Marco Polo or Trackimo would have an extremely minimal effect on flight characteristics. 1.4 ounces is practically negligible. As @Telescott mentioned, your main problem is going to be finding the best place to mount. You've got some space on the very rear of the Mavic. I would avoid mounting on the top due to concerns with compass interference.
OW! that's kind of bigHi Loz,
I have finally received my Mavic but am still in the process of familiarize myself with it before the first flights, both because I find that familiarization quite important and also because the weather hasn't been that inviting for this particular activity, around here.
I also would prefer to fly it with the final chosen tablet, instead of the 2 less-than-perfect solutions I already have, and am still trying to get hold of a 2nd hand iPad Mini 2 for that effect.
(...it is possible I might fly it for the first time this weekend, as I already targeted one of those iPads...)
Now that I have the Mavic at hand, I am finding the 102-NANO TK102 still a bit large for the Mavic amazing compactness. If I end up using it (...which I am seriously doubting, at the moment...), it will be via a patch of Velcro on each battery, so it can be swapped between them, as this seems that spot (...from the very few available...) is the closest to the Mavic's CG and, possibly, also the least prone to create any interference, as the GPS tracker auto-pings the cellular towers.
Because of your very educational thread, the one about that "fail to return + serendipitous finding", I have a Loc8tor on the way and am more inclined to just use it in place of the larger tracker.
I have read that very interesting thread and am confident that, between my own analysis and help from users like Msinger, I will be able to find it, should it stray away like a clueless cat
MK
