The RC Pro Cellular Dongle I ordered last month was delivered yesterday. Just a few notes:
- First off, it worked with a T-Mobile nano SIM card I already had.
- Installation was simple -- remove two screws on the bottom panel and gently lift up. A compartment with a USB-C port and an antenna connector is exposed. Connect the antenna to the 4G port on the dongle and slide into the USB port. I had to slightly rearrange the antenna wire to get the bottom panel to close without bowing slightly.
- The dongle shows up as a T-Mobile 4G connection when you're looking at the home screen or swipe down to show settings.
- I was able to check for firmware updates, the map updated as I moved and zoomed the display and I was able to perform a geo unlock (the main reason I got it).
- My other apps worked as well -- I've tested AirData, UAV Forecast, B4UFLY and Aloft. All worked.
- The FCC ID is 2A2TS2021IG830 FCC ID 2A2TS2021IG830 LTE USB MODEM by Honglink Wireless Solutions Co., Ltd.
- The FCC-submitted User Guide: https://fccid.io/2A2TS2021IG830/User-Manual/Users-Manual-5533544.pdf
There's not much else to it. This is good for me -- I don't intend to get the companion module for the Mavic 3.
