Launch manually and you can go as high or low as you want.Hi Guys,
Just a quick one, how do I reduce the take off height from the standard 1.2m to something like 0.5m or something like that? I tried looking at settings to no avail.
If it's measuring from controller to ground, I guess you could hold the controller at ground level when taking off.Hi Guys,
Thanks in advance
Resetting the home point makes no change to the zero height, which stays the same.Don’t know for sure what happens when the operator resets the Home Point when in flight.
I did not know I could do that!Launch manually and you can go as high or low as you want.
Launching from a car is potentially hazardous.I did not know I could do that!
I always land manually but never knew I could take off manually. Thank you guys! Now I can launch from indide of my car's boot without hitting the hatch
