If you are talking about FAA recreational registration, the FAA doesn't register the drone.Does the new owner need to re register or is it good till 2020. TIA
Yes. Everyone in the US must register before flying a DJI drone outside.Does the new owner need to re register or is it good till 2020
And do you mean activating the drone? If so, the drone can only be activated by the first person that uses it. The second owner and beyond will only need to log into DJI GO and fly.if you mean registering the drone with DJI then yes the new owner would have to go through the same process as you did when you first got the drone
I meant the 5$ FAA registration. In 2017if you mean registering the drone with DJI then yes the new owner would have to go through the same process as you did when you first got the drone
And no ... once a drone has been activated with DJI, that's done.if you mean registering the drone with DJI then yes the new owner would have to go through the same process as you did when you first got the drone
right so its the DJI account that is the important part, thanks for the info i was confusing the two different things sorryAnd no ... once a drone has been activated with DJI, that's done.
The new user would just have to install the app and open their own DJI account.
