Replacing the gimbal cable (not the gimbal camera unit ribbon)
Calgibb
England, UK
Hi all!
I’m currently fixing up a Mavic 2 Pro and both the Gimbal Camera Unit ribbon and the Gimbal cable were torn. I’ve managed to replace the main Gimbal Camera Unit ribbon successfully but I am struggling to get to the Gimbal cable.
I found it was the Gimbal cable when I took the unit apart as the unit ribbon replacement only gave me back the camera feed and no gimbal movement/response.
I’ve searched YouTube and google and can’t seem to find anywhere that shows how to replace it and where to get the replacement.
Cal
Reactions: Former Member
Hi all!
Cal
Taking off the gimbal bridge cable is the easy part. Stripping down the gimbal is the hard part. I have done many.
You have to thread the broken cable down through the hole in the gimbal motor assembly, remove all 3 glued motor covers with a heat gun, remove the camera barrel from the gimbal motor assembly, and replace the LVDS/ribbon cable.
Reactions: Calgibb
Repair service anywhere can be expensive. Information is free and thunderdrones provides that on a daily basis. Without his dedication, the mavic world would be a much different place.
Thank you, I initially thought you were referring his service but I can see now that he is very helpful and well rehearsed in the art of drone repair!
I will take a look at that today!
I have attached a photo just to be clear that I’ve described the correct cable, I am talking about the one pointed to by the red arrow.
How are things going with the repair? I am going to be putting a M2P camera on my M2Z here in the next couple days and would love some input
olivier88
