Weak GPS signal is DJI's way of saying No GPS signal.Does anyone have a work round getting the drone to return to controller to overcome the error message that the GPS signal is weak
One possible explanation is that GPS is not enabled.So why does it work with maps and other navigation apps
If you are flying from a boat, as long as you aren't flying far away and out of sight, you can also reset the homepoint to the current location of the aircraft and that will be just as good.I have done that. thd phone is fine with location on maps etc
The reason is on a boat or other moving targets
Ah no worries Tim apologies - i too want to fly from my boat so i need to test this myself (also iphone Xs)- and a bit worried about the whole rth thing - dont want to pull ashore to set a RTH though its probably a safe bet...I only posted the picture to show what message I get. I have tried many times outside in a varitiy of locations and always get the same message
You can reset the home point to wherever the drone is when it's flying.For those that know - if i were to fly from the boat and hover over the river bank say 3m above it without landing - and set that as the aircraft location RTH - then will that do? or do you actually have to touch down?
The homepoint is saved as a Lat/Long and the altitude doesn't matter.
If the drone was to RTH to that reset homepoint, it would climb to RTH height, fly to a point above the HP and descend until it could descend no more (it's landed).
For any flying from a boat, make sure you are familiar with any operations you will be using and have practised on dry land.
On the water is not the place to be learning new tricks.
Look at the pic in post #1I just searched through the Manual. How do you reset the HOME POINT while in flight? Like in the example above while flying along a river and seeing a nice safe potential landing site (that is not the original home point).
If you are filming your boat/cycle/trek, you'll probably have the drone close enough that you can bring it home yourselfI have no issuers in setting the home to where the drone is eiter form the original home aseeting or form where the drone is at any given momnet. what does not work is asking it to return to controller as it says there GPS signal is weak. It is not just boats but cycles or trekking. wheer you want the drone to come to you and not go home to where it started
If you really, really need to bring it back from way out, one solution would be to get a good Android device because they don't have this problem.I am loving the drone but it has an option to return to controller but it does not work!! It has not been an issue as I have always been able to get the drone home .
I was just wanting to have a belt and braces function in that if I lost sight on the drone it would be a good way of bringing back into vision!
