ok maybe I did not hold long enough ,I was on the tripod mode is that possibly why?For the RTH button on the remote, you need to push and hold a couple seconds for it to work.
We need to know this.How far was the Mavic from the home point? What did it do instead?
thank you so much you probably right didnt give it time ,new at this thanks for your helpDid you give it time to aquire gps lock, sometimes it can take a few minutes, when the light on the rear of the AC is flashing green, and you see GPS mode on your controller, you should be good to go.
Also, make sure you hear " The home point has been set, please check it on the map"
not far since I am just beginning and since i lost the first drone (not as inteligent ) on the first flight it was cheap but still i am scared if it does not return home ,thats a thousand dollarsWe need to know this.
Calm down, deep breath...not far since I am just beginning and since i lost the first drone (not as inteligent ) on the first flight it was cheap but still i am scared if it does not return home ,thats a thousand dollars
Welcome to the forum.
So part 2 of the question, what did it do instead when you pressed the button?
msingers questions may seem trivial but those 2 simple questions can diagnose most RTH issues for new users. You will also learn pretty quick, that he's probably one of the most knowledgeable people where Mavic is concerned.
