I will check the app but it works fine in the daylight. Thought perhaps the system was confused in the dark but it should be GPS driven....correct?Check what you have set in the DJI app ~as one of the RTH options is "Land".
I did not check the exact distance but i was about 3-4 houses from where i took off.Check what you have set in the DJI app ~as one of the RTH options is "Land".
To add some detail to Mr.Salty: from the manual:How far away from the home point is it when you hit RTH?
Aircraft automatically descends and lands if RTH is triggered when the aircraft
is within a 16 ft (5 m) radius of the Home Point.
