Salutare din Romania!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Romania, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
I do not know if you are an experienced pilot or a newbie, but good advice is never wasted…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
Happy, Safe and Legal Droning…
Multumesc frumos, dar am legitimatie pentru pilot de drona.
Nu ai spus dacă ești pilot cu experiență sau începător, așa că ți-am trimis linkul, pentru orice eventualitate... Felicitări, Fly Safe...
Reactions: ZAMOLXE and Steel63
Welcome to the forum! :)
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
kaidoestech
