Sometimes, after you've inserted the card, you have to push the outer edge down or up just a bit to make it latch into place. A friend uses the end of an unfolded leg of a paper clip to do the final push.I have an Air 2s with the RC Pro controller. I'm to re install the micro sd card into the controller. It won't click. It just spring back out. I tried it with the remote on as well as off. No joy. Is there a way to fix this?
Does the RC Pro take an SD card?Look at the SD card and see if you locked it up or the clip is broken.
Phantomrain.org
Gear to fly in the Rain. Land on the Water.
