Smart Controller and apk
Alvaro Lopes
Hi
Van someone explain why constantly this message apears when trying to install an aplication.
In this case its the Ctrl-Dji od Pix4d.
Rgds
For SC which Android version is 7.1.2 what is the best Google Play Service apk to download from the following list Google Play services 17.4.55 APK Download by Google LLC - APKMirror
can you give me a sugestion?
Many thanks
Alvaro Lopes
Go to this thread:
It’s been a bit long. A combination of Kingo Root + adb shell and fast boot oem unlock + custom recovery and guess work.
Details coming after more testing. It will reset the device but seems to be for the better.
It’s not just an apk.
You just have to follow the google services installation part by Aerial Pixel on pg 3 I think.
Hi
Thanks for your help!
Following the steps, I've installed the installer, google play and device-ID.
When running this last a no GSF hex number appears!!!
So I can not register the device and run the other google applications.
Did you had this problem to??
Rgds
Álvaro Lopes
Hi
Rgds
Álvaro Lopes
I had a few errors, but am happy to report that once you load the right version of GSF, you will receive the proper device address, and Goog Play Services works. Follow CERTIFIED AERIALS - How to Install Google Play Store on DJI Smart Controller carefully, and it will work.
My only problem is that I must go and disable Go4, before location services is allowed via other apps. I did not want to root the SC.
ryanhafeman
