Just wondering if any one knows why the
smart controller can't load the Google Play services and the Google App store. I have the Moverios where Google can't be loaded and some have suggested that it is a competitive issue, given Google has or wants their own smart glasses that would compete with the Moverios. But why can't the
Smart Controller get Google Play? There isn't an obvious competitive issue, and there are literally hundreds (if not thousands) of Android devices that have Google Play. Why not the
Smart Controller? This makes no sense to me. Not only will Litchi apparently not work without Google Play, but other good drone apps like Airmap and Wunderground (weather app) don't work without Google Play.
Im sorry I dont have a very technical answer but the reason you cant use Google Play is because the
Smart Controller is using a customized version of the Android OS.
Its not majorly customized but still enough for the 2 OS's to not work 100% compatible.
This is why you 'cant' install a Go4 app apk on the
Smart Controller that is meant for the standard Android OS (I said 'cant', but I should've said 'shouldnt'. I say, shouldn't because while it may install, load and 'seem' to work fine, the Google Play Go4 app is different to the
Smart Controller Go4, even if only slightly, and indistinguishable thru use or sight of the screen... The differences are all in their coding)
Sorry for that long spiel there.
A GREAT EXAMPLE is the Amazon Fire Tablets. They run a customized, and slimmed down version of Android but there is a method to install Google Play onto those tablets.
If its possible, I expect there will be folks working on making that happen on the
Smart Controller BUT I STILL WOULD ADVISE AGAINST THIS. The only reason the Amazon Tablets can run Google Play apps is because its been slimmed down, so there's not much conflicting code. The
Smart Controller custom OS isnt likely slimmed down as it needs alot of 'juice' to run the Go4 app, along with its integrated Screen record & HDMI out functionality.
Not very technical I know, and its all just my own opinion but I hope it helps a bit?
