some guy doing an FCC hack permanent for RC pro Controller
Très gentil de votre part, je vous aide 12 fois avec une question, vous donnez des conseils et suite je n'ai plus de nouvelles de vous ? si tout a été résolu ? Si vous traitez les gens comme ça ! !S
Very nice of you, I help you 12 times with a question, provide tips and then I don't hear from you again? whether it has all been resolved? If you treat people like this!!.
Non non , y stop this mode .
Reactions: Agaam
Im with DJI RC on 1.03.0700 with FCC active. Did someone try 1.03.0800 and repatch the controller?
Thanks!
I don't know how to remove it, if an administrator or moderator could remove it that would be great. Sorry
Nobody who wants to try the 1.03.1800? :)
Changelog from .1700:
Overview
  • Date: 2024.10.23
  • DJI RC Remote Controller Firmware: v01.03.1800
  • DJI Fly App Android: v1.13.11
What’s New
  • Fixed some minor bugs.
I think it should work, or not?
There is a new Version .1900 - No chance to update, right? :(
DJI RC Release Notes
Date: 2024.12.04
DJI RC Remote Controller Firmware: v01.03.1900
DJI Fly App Android: v1.13.12
What’s New
Why would you expect it to? Water and foliage absorb those frequencies very well. You can throw as much power at them as you want - all you'll do is heat the leaves up a little.
Ability to get through obstacles is primarily a factor of frequency not power.
This is the case for all DJI drones. Power hacks will only help in clear path conditions.
not true as it helps a little bit but not much like you said. I should know as I have and Alientech DUO 2 amplified antenna. I get a stronger signal for sure going through trees and buildings otherwise I wouldn't use it.
Hello,
I updated to 1900 and installed fcc patch, it wrote that patch installed successfully, but when I connect the drone I see that patch don't work.
Do you know how to downgrade RC to version that support fcc patch?
What I know it is not always only about RC fw version, but also Fly app version. Try Fly app 13.9 and if it works go up a version from there. On my Mavic 3 and RC Pro, the version 14.x does not work despite patched RC Pro.
Reactions: fischli
Cześć, do jakiej wersji mogę bezpiecznie zaktualizować kontroler rc2 1000000308.jpgz zainstalowanym FCC? Na razie zatrzymałem się na tej wersji. Czy jest możliwe zaktualizowanie samej aplikacji djifly? Proszę o jakieś informacje
ahmad haj ali
