Some issues with Osmo Pocket
digiteye
Hi, after using this cute device, I've found a few things that may cause problems. Please check it out.
You could probably have typed 4 lines of text and made something clearer than this 6min video.
Still have no idea what your point about the file naming is.
Reactions: MrEdCeD
Most of this is solved by the wireless adapter, no physical conection and phone doesnt draw power from the device. As for the file names I really don't see how that can be an issue tbh it takes seconds to rename multiple files if you really feel the need to on raw footage.
Despite I hate to watch a (quick produced) video for that little information from the DJI Osmo Pocket FAQ, the charging is not to be blamed on DJI but on Android:
Q: How come the Osmo Pocket keeps charging my phone when connected?
A: According to AOA protocol of Android, Osmo Pocket must provide 5V 500mA power to the Android device when connected. This will result in reduced battery runtime, however, the Osmo Pocket allows you to charge it when it’s turned on. Adding an optional Wireless Module can also prevent the reverse charging from happening while not compromising advanced control and features.
Reactions: fozzzy
It's kind ridiculous that DJI says to add a WiFi module, as that drains a lot of power too, instead of providing a solution. So here is a solution
InchWorker
