Signal problems FCC and 4G
It is shame that the antennas can not be tilted upwards. When the drone is directly overhead you might need to hold the controller in very uncomfortable position to get the flat parts of the antennas to face the drone as per the instructions🫤
I completely agree, and am surprised they won't even let them extend out at all, only rotated down. Basically, the screen must always be kept parallel to the top surface of the controller for the antennas to be pointed at the drone when you tip the the entire extended set up at an angle to view the screen.
Last week I decided to return my drone to DJI and this week they will let me know if drone has a problem or if it is something else. Below the photo of poor reception. I even tested it against my old mini 3 pro and my small drone did much better in the same area....
I also talked to few people and it seems some people also have this problem, not only me.
BTW. I use RC2 and I do know how to properly adjust antennas, so this is not the problem.
Except the RC 2 has entirely different antennas that flip out and up.
These ONLY rotate down, and cannot be flipped out in any way.
Anyone tipping the screen up from the controller will have their antennas pointed at the horizon, instead of the sky and the drone. The screen and the top controller surface must always be parallel to each other for proper antenna orientation, so you also tip the controller up to have the screen tipped up.
Also forget about flying overhead! You'd have to hold the controller perpendicular to the ground.
A possible consideration for future purchases.
Something to consider in the external antenna position is there are also internal antennas besides the external ones that have adjustment ability. Below are from an RC PRO and will be similar to what hides in the RC PRO 2.View attachment 182694View attachment 182695
When you say adjustment capability for internal antennas, how exactly would you go about adjusting the internal antennas, assuming they are also present?
Internal antennas are not adjustable. Probably my wording could have been better.
Your wording may have been a little confusing, but I think you make a good point that adjusting the direction and elevation of the controller to optimize signal strength may involve more than just optimizing the direction of the external antennas. Some positions of the controller may increase signal strength to the internal antennas, which may be the ones needing reorientation by slightly adjusting the angle of the controller laterally in one direction or another. When signal is attenuated, experiment with direction and orientation to maximize signal bars, assuming the external antennas are already optimized.
I had the same issue with terrible range in CE when i first got my drone with RC 2 but after a FW reflash it worked great. First flight I only got to 1.2km before the signal died but after the flash it went past 5km and signal only dropped 1 bar. Try the FW refresh via Assistant 2 again but refresh both the RC 2 and Mavic 4 Pro.
At the end after inspecting my drone, DJI decided to replace it, and I just got a brand new Mavic 4 Pro. So it seems it was a real problem.
This weekend I will test my new drone and let's hope the signal will be much better.
I wouldn’t read anything into DJI's replacement of your drone, after having sent it in. DJI is notorious for replacing drones in a vain attempt to fix a reported problem that is often not a hardware problem at all, but merely an undocumented change in functionality, or an as yet undocumented and/or unresolved FW issue. Your issue may be limited to the dual use of 4G and OS4+, together, which is unique to China, and a few other 4G supported countries.
Let us know if your problems have disappeared by merely replacing the drone. I suspect not. It is likely a FW issue relating to the dual 4G and OS4+ interactions that may take a while to get sorted out.
Try turning 4G off and see if your range on OS4+ alone for LOS flying is still hindered.
I'll bet it is just fine, like everyone else's, who is not also using 4G!
Reactions: Starz
I'm from Brazil and I have the Creator combo. We're already using the CE standard here, but even so, compared to the Air3s signal, the M4 signal is much lower. I believe that in an update they will adjust these things. The signal loss is frequent, although I always fly in the city and I've managed some flights over 4km.
Reactions: Tommy87PL
Zero range issues with my M4 with RC Pro 2 or my A3S with RC 2. I'm in North America, our versions may be different to those sold in China.
finekio
