I ordered it from a Japanese-based seller and had it delivered by FedEx in 7 days.
mavicpilots.com
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
First, if you have not already done so and you want to fly your drone recreationally, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). This Link is to the Pilot Institute Web Site where you can get your TRUST Certificate. (FREE…)
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. This link is to the FAADroneZone where you can register your Drone. The cost is $5.00…
faadronezone-access.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
30+ free and paid classes to fly your drone. Pass your FAA Part 107 license exam, learn how to fly your drone, and more.
pilotinstitute.com
Since you live in Pennsylvania, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Air 3S, including the User Manual.
Download the software, user manual, and other materials related to DJI Air 3S. DJI Air 3S boasts a 1-inch CMOS primary camera and a 70mm medium tele camera, both delivering exceptional image quality with up to 14 stops of dynamic range. Both cameras support the new Free Panorama feature that...
www.dji.com
Fly On and Fly Safe…
