Stuck in endless firmware update.
I have a Mavic 3, Mavic 2S and the RC Pro controller. Since the update about 3 weeks ago or so everything has been working great. Launch DJI Fly, choose either 2S or 3, connects quickly. Change aircraft, choose the right one, and it connects quickly. Had no problem switching aircraft.
But after a recent update (not sure which one), it is not working.
When choosing aircraft (2s or 3) the last aircraft flown is good and connects quickly.
If I switch to the other drone, it comes up with “Firmware version inconsistent. Update firmware before use” I assume it means the controller firmware.
So I update, and it connects quickly.
But when I switch back to the other drone (doesn’t matter which), then THAT drone says firmware is inconsistent. So I update, it connects fine.
And again when I switch to the original aircraft, fire up Fly, and guess what, it says firmware inconsistent!!!
So I’m stuck in a loop, the last aircraft updated will fly, the other is inconsistent. I update, and they switch places.
Obviously if I’m in the field I can’t update (no wifi), so I can’t switch aircraft.
And the firmware versions don’t seem to change, they are always the same even after updating.
Also, after each “firmware update” it also says controller will restart, but never does. But I have restarted it, and it doesn’t make a difference.
I believe this started a few days ago, but I haven’t been flying both aircraft, so not sure.
So what am I missing? Am I doing something boneheaded? Has anyone else seen this?
Any ideas?
Mavic 2S firmware 02.04.2130
Mavic 33 firmware 01.00.0500
RC Pro Controller firmware 03.01.0500
Go Fly 1.5.10 (1070 official)
Any ideas?
