I will refer to this excellent discussion from the Phantom forum re work, efficiency, optimal flying conditions for these motors:
I did some calculations (just for fun) to see the motor efficiency of our
P4 motors in real life. The data is from a 62030 ft run that I did yesterday obtained directly from the .dat file in the
P4. I flew the
P4 at a constant 33.6mph or 15m/s and for their given power of 800kV and...
phantompilots.com
This was by no means optimal. I knew it and was prepared. Upper atmospheric conditions (6-700feet to go over the mountains) were also adverse. DJI advertised max HD transmission range of 8km and a flying time of 31 mins are two separate variables each achieved under ideal conditions. One is the inverse of the other as you lose efficiency faster you travel.
There were some issues with the range of the
SC and that was being tested today, which I'm pleased to say worked awesome.
Under normal flying conditions, SRTH triggers around 3.8 miles.
