Time to get back at it
McGanksta
Colorado
Hi there,
Its been a few years I think, I purchased a Mini 2 as a graduation present for my self.
I ended up having to go though a lot of other training/certifications and put down the drone.
Well it is time to get back at it.
I never really developed my skills, and now as the weather is going to start getting better, it is time to develop my piloting skills
Are there any free resources, classes, or training out there that has step by step progress?
Edit to add: I have upgraded my phone from an iPhone XR to a S23 Ultra...and I am thinking about moving to a 3rd party flight app
Thank you all
Hi there,
Thank you all
Hello from the Crossroads of America McGanksta
No training required if flying recreationally other than taking it low and slow at first to learn about the aircraft.
Read the manuals a few times too.
DJI Mini 2 - Download Center - DJI
You should take the TRUST test and keep a copy with you when you fly. It's required now.
It's a free no fail test that's easy to take.
Good luck and welcome back to the Forum. :cool:
I have my TRUST, and I did fly it a bit when I first got it, but then life....|
I have been a member here for a while, just have not been active!
Thaks for the input
And at some point, I want to get my 107 and do some low-key real estate work for some friends.
Welcome back to the Fold…
As an "Old, New" Drone Pilot, there are a couple of Legal Things you may need to do that you did not do before…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Colorado, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Even if you have flown Drones before, here is some Good Old Fashion Advice so you get back into the sport gracefully…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
I just updated all the firmware.
Found a few videos on some simple drills, really need to commit to getting muscle memory of what the sticks do.
Going to make a few "targets" out of cardboard, or plastic lids, for my drills.
I do have a question, is there anyway to disable the high altitude warning I get because I am at 7k feet to start with?
Thanks
Welcome Back! :) Enjoy the forum!Thumbswayup
I don't understand how that can be happening, your drone initializes it barometric setting at power up and it should start at Zero altitude whether you are sitting in death valley, or on Denali (formerly Mount McKinley) the lowest and highest points in the US...).
Does it happen every time you power up, How soon after powering up?
Are you sure you have not set the Maximum Altitude in the Safety Menu, Flight Protection to a low altitude?
Can you send us a screen shot?
I can send it tonight
Hi there,
Thank you all
I think you will find a number of ‘getting started’ training videos on YouTube. Simple forward back, fly in a square etc. practice flying towards yourself and moving left and right.
I wonder if it is an operational ceiling issue? I am at almost 2200 meters before I ever fire her up.
Reactions: SeaPig
I think the Operational Ceiling is more a warning as at that altitude, it is not going to fly very well, not enough air for those little props to grab to fly efficiently... Not a firmware limit...
Just checking, you have set the Maximum Altitude in the Safety Menu, Flight Protection to a much higher altitude, like maybe the maximum?
You also might want to PM (start Conversation) with @msinger with all data and screen shots...
After That, I would suggest you log onto DJI Forum and ask DJI Stephen ( a super moderator)...
Good Luck!
Freakazoid
