Tiny micro crack and sligt protrusion on fuselage
Oliver mavic air 2
Finland
I recently noticed two sligt protrusions and a tiny crack on the fuselage right above both front leg hinge mechanisms. I believe that the screw in the mechanism is protruding up towards the plastic above which has now caused a tiny micro crack, I fear that this crack might expand.
has anybody else experienced a similar problem with their mavic air 2?
what should i do?
the micro crack is barely visible at the left side of the red line, but it is still there
you can also see the plastic slightly protruding att this point on both sides
welcome to the forum, how long have you had it ,did you get care refresh
what should i do?
Im thinking that is more what most of us might consider to be a Micro Scratch.
Phantomrain.org
Gear to fly you Air 2 in the rain
Coal
Reactions: Motorcycle Rider
Thak you :), i’ve had it for 25 days, and there is a 30 guarantee on it, the micro crack is only visible in sunligt from a specific angle, so i wonder if the store vill accept the return
Reactions: old man mavic
well thats the way to go then good luck
Do yourself a favor before you return it , what about the rest of the drone, you have a chance to check out all the functions , does it connect, is the gimbal perfect , does the sd card work nice,
You may take it back but than get a dud , if you can check off this one on the essentials you may want to a least really test out the functions.
Phantomrain.org
Coal
Yes i could be but it doesn’t reflect ligth in the same way as a scratch and more like a crack. And it is also in the middle of a slight protrusion which to me indicates that it is a crack maybe, but still not 100% sure
Reactions: Phantomrain.org
I've found the pictures from the other post:
Hi All, I'm new to here but I had the feeling that I should share my story as I have exactly the same issue here... From a tiny protrusion its became a nice tiny crack. Exactly the same place. I've contacted with the DJI Support, waiting for their answer what to do now. Also the same issue at one of my friends with MA2. It seems a material / construction issue to me.
Hi! Yes I'm here. I have same issue. No crash, no accident. Flight time : 10h / 46 km. 93ECED33-83D7-41FA-B0AD-1BADC19F8A3A.jpeg
Looks like DJI in a constant effort to reduce the weight of the aircraft is using a lighter plastic, similar to the MM. This plastic feels thinner, fragiler than what they used in the Spark, the MA1, etc
what should i do?
My Mavic Air 2 developed a crack after only six months of owning it. DJI is repairing it for me free of charge.
I had the same cracks.. dji replaced my unit under warranty. Stating it was not due to pilot error. At this point I'm pretty sure they are accepting that it is a manufacturer defect.
venoom2001
