I have the 7pro. Its a great unit. The 8 pro is faster, lighter, bigger and more futureproof as it runs a newer version of android. I would probably spend the extra.I would like to save $ and buy the & Pro since it has the same Nits as 8 and is $125 less. Is that a bad idea or should I spend the extra coin for hte 8 Pro?
Was about to pull the trigger but I do not want to waste money. I have an Iphone 13 which already sports like 1000 nits.
What would be the real advantage of a Tripletek? a couple hundred more Nits. but a bigger bulkier device too.?
The Tripltek is very much bigger and bulkier but after that there is no comparison. The screen size is exponentially larger. The 1200 nits is the real thing..... iPhone can only achieve 1000 nits for a few seconds at a time and normally peaks around 800 nits. The iPhones suffer from overheating and dimming when used as a screen for long periods. My iPhone 12 becomes unusable after awhile in warm weather, dimming the screen so much I can't see.Was about to pull the trigger but I do not want to waste money. I have an Iphone 13 which already sports like 1000 nits.
Looks nice.... especially with the included mount. This might deserve a serrate thread if you have any experience with using it.Not to go off topic.. but Thor has released a less expensive competitor to the Tripltek 7. It includes the mounting bracket and a few other goodies. Those who don’t go for the Tripltek 8 should check it out.
Trying to make a copy of the TripltekI will not consider the Lifthror, The Tripltek 7 Pro keeps its value, after a year I sold mine for $550 when I moved to the 8
