- Joined
- Oct 20, 2017
- Messages
- 295
- Reactions
- 155
- Age
- 45
The BT-300s come with a built-in system update function. Update the system to the latest version before using the product.
You can check the update package from [Settings]. Select [ gear] from the APPS list, and then select [About device] - [System Update]. When you are using the latest system, select [Check Now] to check if there is a newer version available.
Connect the AC adapter to the product, and run the update while the product is turned on. If the amount of battery remaining in the product drops below 50%, the system update stops. If the update stops, turn off the product, charge it, and then run the system update again.
Select [Download].
Follow the on-screen instructions to download the update package.
Select [Start Update] on the following screen.
The product restarts and the update status is displayed on the screen. When the update is nished, [Complete] is displayed on the screen.
Press the Power button on the controller to turn o the product.
The next time you turn on the product, the updated system starts.
Select [Download].
