There are VND filters for drones. They have somewhat less utility on a drone because you still have to bring in the drone to change the ND strength and still have potential issues with X pattens so it’s not quite as beneficial but they do exist.Why is there no variable ND filters available for drones? Is it a physical limitation issue?
As you might imagine, while decent quality all in all, these ND Filters we find available for our drones are not, to my knowledge, on par with the best larger glass filters you might find on a dslr. I have zip to backup that statement - that's just my assumption based on ignorance. (but it's still mine . A color caste from an ND filter is such a common thing. When you are looking through an ND filter your eye compensates and makes it look just fine which is why the world doesn't look yellow when we enter a room with incandescent light after being outside. It always looks normal. It isn't until you view an image or video you have taken that you will learn if there is a color caste, and it's never surprising to find something of a minor color caste from an ND filter so don't be shocked - or concerned. With a little luck there is white area in the image or at least a neutral grey of some shade and you can color balance on that; there will also be an auto setting on most devices and that should normally do the trick, easy peasy. A minor color caste is no big thing. So a super clean optically excellent filter with a slight color shift is a better thing than a mediocre lens that creates flare (or whatever) that has no color caste. You can totally and completely adjust a minor color caste (and any ND filter color caste will be minor. the market will take care of THAT much) in post but a poor quality lens will cause problems that are not so easily solved if at all. Because VND filters require two separate filters they will ALWAYS be less perfect than a single ND Filter, however the best of them, from what I have gleaned watching many vids (because I don't own a VND filter)....from all the comments I've heard, the best of them are good quality so while theoretically inferior, they are decent enough that many people like the top brands out there. People are pleased with their VND filters. Freewell, PGYTech, Polarpro and more, I'm sure. I have Freewell and Polarpro and they are both excellent. If you came this far, here's a link to an interesting review of ND Filters that discusses color caste.Thanks for the replies. I think the X effect becomes an issue when a VND is used close to its maximum range of stops. A common 2 - 400 VND should be good for 2 - 256 before the X effect becomes an issue.
Colour caste could be an issue. For those who have used VNDs on drones have you experienced colour caste issues?
I have a VND on my Sony A6500 made from Schott glass and I have no issues with colour caste.
