Which MicroSDXC card to use?
Just
I want to buy a 64gb microSD card.
I want to buy a good one, but obviously not pay for speed that will never be used.
What is your guys opinion on which card to get?
https://www.amazon.de/SanDisk-Extreme-microSDXC-95-MB-Speicherkarte/dp/B010NE3N3S
https://www.amazon.de/SanDisk-Extre...481755653&sr=8-2&keywords=sandisk+extreme+pro
https://www.amazon.de/SanDisk-Extre...1481755925&sr=1-1&keywords=sandisk+extreme+64
https://www.amazon.de/SanDisk-Extre...1481755925&sr=1-3&keywords=sandisk+extreme+64
Will it matter for the Mavic?
Will it significantly matter for transfer to my computer?
Should I go for a different brand?
The Mavic can only write at a max speed of 7.5MB/s. You'll cut down on file transfer times between your computer if you go with a faster memory card though. The brands you listed above are choices. You can find some others here.
And always do your video/photo transfers by pulling the SD card out of the Mavic and using a card reader on your computer. The transfer times are substantially greater, and you won't waste an entire battery charge getting them there.
I have the SanDisk Extreme Plus 64gb it works perfectly and whenever I do transfers I take it out and use a SD Card Adapter in my MacBook.
Reactions: scalmes
I walked into Costco and saw they had a two pack of 32GB Sandisk extreme's on sale for $24
I believe they were 10mbs... so plenty fast enough for the Mavic
I am using one of these as I have used them in other devices and they have all been very reliable
Samsung Memory 64GB Evo MicroSDXC UHS-I Grade 1 Class 10
They are cheaper than the SanDisk Extreme Plus cards.
SanDisk Extreme Plus microSDXC 64GB bis zu 95 MB: Amazon.de: Computer & Zubehör
SanDisk Extreme Pro microSDXC 64GB bis zu 95MB: Amazon.de: Computer & Zubehör
SanDisk Extreme 64 GB microSDXC Speicherkarte +: Amazon.de: Computer & Zubehör
SanDisk Extreme 64GB Class 10 microSDXC for Action: Amazon.de: Computer & Zubehör
I have a San disk ultra plus 200mb v 10 but pro says video has stopped cash is full what am I doing wrong
The Mavic Pro spec' (manual v2.0) lists the 'Supported SD Cards' as
This means that you'd look for cards with the UHS Speed class 1 logo - which looks like a U with a 1 in it ... Personally, I use U3 cards in my Mavic Pro Platinum and never have any video recording issues. All of the cards that you have posted links to are UHS speed class 3 - which mean that they have a better minimum sustained write speed (30 Mbytes/s rather than 10 Mbytes/s). Any of the Amazon cards you have linked to would be OK in your Mavic Pro.
VelosiFed
