Whining sounds
I'm too lazy to go back and read the entire thread, but have you replaced all 4 props yet? That's probably the 1st thing I would do and see if it helps.
No problem,I was going to ask about the littlest of scuffs and if that would make a difference,I did swap 3 of them but will do 4th when I get to it and before I fly again.
Thanks again
Bob
Thanks again
Bob
Im not sure that scuffs would cause a noise but cracks or chips might. Most of the time it's more of a buzz when that happens.
Hi Rob,what is a 1.5mm torx,ie.t2,t3?
I've come to the conclusion, it's the left front,both warmer(not hot) than the others, actually both front were warmer,left more so,the back 2 we're cooler, only flew for about 5 minutes and the sound was I believe from the left front, well I've got small torx,small Phillips and slotted but you got me on a spluger ,never heard of it but did see one in a video, basically a plastic pry so as not to scratch I think.
Sorry I couldn't resist. I do try to help other people from time to time with my (limited) knowledge but I mostly just lurk on the forum and occasionally try to give fellow members a laugh with an amusing comment.
somatic
