Looking forward for your report.Yes, just did it myself. On my way out the door now to try it.
Have you tried with wi-fi or DJI Assistant 2?Firmware update just failed twice. Reason: network disconnection. I'm a bit wary to update it now.
Will do what I can to test.
Wi-Fi. The last update I did worked flawlessly over Wi-Fi. Maybe it's because my battery isn't fully charged only 55%Looking forward for your report.
My burning question is, have they reverted to the cancellation of the failsafe landing with the upstick input?
Worked fine for me too but is kinda unpredictable, and it didn't work to downgrade. Not at all.Wi-Fi. The last update I did worked flawlessly over Wi-Fi.
Hi all, brand new to the forum, but I'm having the same issue. I keep getting to 1% and then it craps out and says it couldn't update because of a network disconnection. I've tried WiFi, and then tried data as I have heaps of it to spare, but in both cases it crapped out before it reached 5%.Firmware update just failed twice. Reason: network disconnection. I'm a bit wary to update it now.
Just got mine to update. I moved to the room where I have my Wi-Fi router and then it worked perfectly. For some reason my settings did not reset?Hi all, brand new to the forum, but I'm having the same issue. I keep getting to 1% and then it craps out and says it couldn't update because of a network disconnection. I've tried WiFi, and then tried data as I have heaps of it to spare, but in both cases it crapped out before it reached 5%.
Any ideas as to why this is? I'm on Nexus 5X using the DJI Go 4 app.
Cheers!
Cheers!
