Samsung Galaxy Tab 7"
How about the Tab E ??
Repeat question but did not get answer
Thanks
I use a tab e and it has one problem will not sync to go 4 unless you have it powered off. Power up quad ,radio, and then power on the tab e. Tried every suggestion i could find this is only cure. If done any other way it will give you the disconnect alert in upper left hand corner of go 4 and not ever connect.
djiNonMini
