400 Foot Rule - Trees
CMavicPro2
Boulder Creek, CA, USA
As a relatively new flyer, i have a question about the 400 foot rule if anyone knows. I have a group of trees on my property that are 150 ft high at their peak. Would the trees be considered structure that i can fly above an additional 400 feet or is the rule only for man made structure's?
Thanks in advance
Charles
You're welcome. Honestly, flying at 650 feet wouldn't give you good footage anyway. Another 40-50 feet above those trees will likely be the safest, legal and best footage.
Thanks in advance
Charles
Besides, That rule only applies to 107 certified pilots, last i checked. Recreational pilots aren't allowed to fly over 400ft in USA period.
Reactions: DoomMeister
Here is a list by the FAA of what they call structures. Doesn't look like plants / trees are included.
  • AG EQUIP (agricultural equipment)
  • AMUSEMENT PARK STRUCTURE
  • ANTENNA
  • ARCH
  • BLDG-TWR (latticework greater than 20' on building)
  • BRIDGE
  • BUILDING
  • CABLE CAR
  • CATENARY (transmission line span/wire/cable) (* See Note below)
  • CONTROL TOWER (airport control tower)
  • COOLING TOWER (nuclear cooling tower)
  • CRANE (permanent)
  • DAM
  • DOME
  • ELECTRICAL SYSTEM (components of an electrical distribution system)
  • ELEVATOR
  • FENCE
  • GATE
  • GENERAL UTILITY (components of a general utility system)
  • GRAIN ELEVATOR
  • HANGAR
  • HEAT COOL SYSTEM (components of a heating and cooling distribution system)
  • LANDFILL
  • LGHTHOUSE
  • MET (meteorological tower)
  • MONUMENT
  • NATURAL GAS SYSTEM (components of a natural gas distribution system)
  • NAVAID (airport navigational aid)
  • PIPELINE PIPE
  • POLE (flag pole; light pole)
  • POWER PLANT (buildings and equipment used for creating electric/nuclear power)
  • REFINERY (buildings and equipment used for purifying crude materials)
  • RIG (off-shore platform)
  • SHIP
  • SIGN
  • SILO
  • SOLAR PANELS
  • SPIRE (steeple)
  • STACK (chimney; industrial smokestack)
  • STADIUM
  • TANK (water; fuel)
  • TETHERED BALLOON (weather; other reconnaissance)
  • TETRAHEDRON (solid, pyramid-shaped landing direction indicator)
  • TOWER
  • TRAMWAY
  • TRAMWAY PYLON
  • T-L TOWER (* See Note below)
  • UTILITY POLE (telephone pole, or pole of similar height, supporting wires)
  • WALL
  • WIND INDICATOR
  • WINDMILL (wind turbine)
  • WINDSOCK (flexible, mast-mounted cylinder showing wind direction and strength)
robertrfletcher
