Yes there is.if the house is not in a congested area then you're ok as long as you are 50 metres up. If it's in a congested area then you can't fly over it. No definition of what a congested area is though.
In Australia, it's 30m from people, and as a general rule, I assume it's 30m from properties as well.
Yeah. I thought there were rules about flying distance from people AND property.Our rules were update a few years ago, and flying above buildings was removed, not sure why.
I thought it was a fair enough rule.
Our latest rules only mention not flying above people, 30m laterally.
There is the part that says "You must not operate your drone in a way that creates a hazard to another aircraft, person, or property"
The aircraft, people part of that is specifically defined in the rules, but how is that part related to property specifically definable ?
Perhaps just courtesy is added, high altitude, filming horizontally, not hovering / panned down, just simple flyover, like so many aircraft do a day.
Common sense (or lack of it) could see this part of the rules re-written again sometime.
And the distance rule is more of a cylinder, not a sphere. I am not worried if someone's drone fall 30m in front of me, but I'll be worried if it fails 30m above me. Which way do I run? If the rules are not clear, it should be clarified. To just state 30m or 50m from someone, it doesn't mean it's safe to fly 30m/50m above someone. I don't want to hurt anyone AND I don't want to damage anyone's property; car, house, etc.
Nobody likes a drone over their house, but Google Earth is fantastic.
Then why do they make rules concerning the use of photographs?Yeah, Google Earth is fantastic because it's not a physical aircraft that could, though not likely but could, fall out of the sky on to your property causing damage or worse. The airspace regulators are not interested in the photographic aspect - for them, it is and will always be about Safety and Risk.
OK, so now you're going off on a tangent not related to this discussion. You initially made what I consider to be an irrelevant comparison to Google Earth.You can take a drone photo, but you can only charge for it if you can afford CAA's PfCO.
That's a government thing. If you want to make money, they want a slice of it. Nothing to do with safety.You can take a drone photo, but you can only charge for it if you can afford CAA's PfCO.
Cant help with UK regs but in aust its illegal to fly within 30m of a person OR where a person may be. very wide definition but its all about to change, for the better i hope, A regulator told me to visualise a cylinder that is 60m in diameter. you cant fly in that zone.Got some verbal from a [Language Removed by Moderator] insisting that it is illegal to fly over houses in the UK. I said it was not as long as you are 50 meters up. Am i right?
