I am a Titan Switch fan. The Omni with the 9db whips, I run out of battery before I run out of signal.
Picture please? I’d like a look at the quick connector.More bucks, but I’m an Alienware owner. 13dB signal and 2 quick disconnects for takedown. Like above I have max signal strength far beyond the “point of no return” distance.
Whatever you select, remember that even though signal strength is increased, all range extenders focus the control signal beam so orientation of the controller to the drone is more critical.
Did you guys do your own modification? Was it easy?
It is a bit tedious, but user instal is not difficult. Here’s the install video url on the website showing every step... about 30 min, took me a solid hour plus but I’m a bit OC. There are other options on the website. The appearance and connectors (2 finger screw rings) are best seen beginning about 9 minutes left in the video.Picture please? I’d like a look at the quick connector.
Thanks
With the Titan Omni and whips not critical at all. Human nature and VLOS keeps us facing the AC.all range extenders focus the control signal beam so orientation of the controller to the drone is more critical.
Not yet. But it’s a thought.Anyone do this to the SC?
Question... I purchased the 4Hawks XR to increase my range for the mavic pro 2, but do I also need to purchase and install some amplifiers? What do amps do and what are good ones for this situation? Anyone have any info on this or should the antenna upgrade be sufficient?
