Any way to save Go4 settings before updating?
Pegasus1
Seems like the DJI Go4 app tends get its settings either wiped back to defaults or changed after you download a firmware update, requiring you to tediously go through all the menus and check everything you have so carefully laid out the way YOU want.
Is there a way to save your current Go4 settings as a profile before updating to avoid risk of a crash or other problems? In Windows you can save a Restore Point using System Restore in case something gets Fubar'd, you can go back to a prior known good state. This would probably also be a good practice for use with the Mavic.
I take screenshots of my settings.
Not really, because the majority of the settings are in the craft itself and not in the app.
The app only reads and writes them while connected.
Wesleydjimavic2pro
