ATTI Mode ??
Hi. I am a Mavic Pro user and I also have a question about ATTI Mode if someone here can answer for me.
1) Is it normal that I can move the drone but cannot see anything visual in my screen? I am fine with flying in ATTI Mode but
if I want to film something I need to know where my carmera is pointing right?
2) How can I turn off the ATTI Mode? It is due to lack of satellite in the nearby area or is it due to disturbance from some antena?
  1. ATTI mode doesn't have any effect on camera view - if that's not working then you have a different problem.
  2. Unless you selected it in the first place ( which first requires changing one of the firmware parameters that controls the mode switch) then you cannot turn it off - it's selected by the aircraft flight controller if there are insufficient satellites locked to get an adequate position solution or if the IMU / compass / GNSS data start to disagree.
Thanks for your reply. I actually never change any settings and just try to use it as it is. Weird thing is that sometimes I have the carmera view and sometimes I dont so I have no clue how to control this and it bothers me a lot since I cannot view anything with my screen. So ATTI mode doesnt have any effect on camera view is what is normal than I should get to DJI service right?
Both ATTI and no camera view could be due to a number of issues. I'd suggest posting a flight log here when this happens before simply sending it off to DJI - the log may well provide definitive answers.
Sorry it was OPTI mode. Is it normal that there is no display in OPTI mode?
If I was having periodic dropouts of the Live View (camera view), I would swap out the link cable between the remote and my flight monitor. That would be the most likely cause if it was not a signal strength issue - such as antenna positioning or distance from the drone.
I just solved the problem. I turned off and turned on the smart phone and everything solved.... Maybe due to the latest software update either on MAVIC APP or Smartphone such reset was neccessary. Thanks for your help and good flight!
kmart
