I have not seen one, It's not as convenient but you can always click the battery level icon in the DJI Go 4 app and it will bring up this screen:When I flew electric RC airplanes I had a stand alone module that checked my lithium batteries. It told me volts and amps remaining on the batteries. Is there an aftermarket device that does this for the pro 2 batteries?
Will it discharge as well?With this charger you can see the voltage and the current when charging.
I bought it at Aliexpress for a few dollar and it works fine.
Of course not, I use this device for more than 1 year, about 4 months ago I got swollen batterys, it was simply reimbursed under warranty by DJII paid a lot for the warranty so using the third party charger could void it but thanks for the tip.
cheers
Now for that DJI could void the warranty when charging with a third party charger, but there had been a trend with the batteries swelling even with stock charger.Of course not, I use this device for more than 1 year, about 4 months ago I got swollen batterys, it was simply reimbursed under warranty by DJI
What intelligence of any relevance is outside the battery?Now for that DJI could void the warranty when charging with a third party charger, but there had been a trend with the batteries swelling even with stock charger.
Normally though warranty wouldn't be voided unless you have a power issue and it can be seen the charger caused the battery to fail. Much of the intelligence is in the battery though.
When you ask for warranty you don't have to send back the old battery, they only ask for the serial number.Now for that DJI could void the warranty when charging with a third party charger, but there had been a trend with the batteries swelling even with stock charger.
The voltage can be seen on the app. The "amp remaining" is expressed in %. E.g. if the battery capacity is 10000 mAh, 50% means there is 5000 mAh remaining.It told me volts and amps remaining on the batteries. Is there an aftermarket device that does this for the pro 2 batteries?
