mnis
Have you noticed the temperature difference between the suspect and an obviously good battery under the same conditions?Hi everyone! It’s been a while since we were on this thread for this battery issue. I have recently used the said battery a couple of times and the”bulge” remained the same.
However, I noticed that it seemed to get hotter more quickly than my other battery.
If I remember correctly, it reached something like 47-degrees after less than 50% flight time (not very sure of this figure but definitely hotter to the touch).
What is the allowable maximum temp?
It is generally said that the lithium in the battery reaches a critical temperature above 60 degrees Celsius. I always worried about my batteries because they felt extremely hot immediately after flying, but nothing ever happened.
So if you can answer my question with YES, then you do not have to dispose of this battery hastily. As long as the battery shows no visual change, there is no reason to worry about a sudden explosion or fire.
Against the uneasy feeling:
Stop using the battery to fly. You could still use the battery safely on the ground to perform updates, make settings in DJI Go, or charge USB devices if the adapter is present.
According to your previous statements, it could not be determined with certainty that there was actually a problem. Now you say that the (only tangible) "bulge" has not changed. There is no need to panic. The battery will continue to behave normally unless high demands (flying) are made.
Only under extreme load would a weakened or damaged battery swell until it bursts. Provided the storage and charging area is located in a specially protected environment, I would not worry more than with all the other of my batteries.
Or sell the battery on eBay as a defective item. You'll be surprised how many interested hobbyists there are. Then get yourself a fresh battery so you can fly with less worry again.
