May be carefully cutting it out? vibratory saw type tool? or see what is in the dremel kit. maybe a tiny drill bit could start breaking it free? Does it charge if you plug the drone USB in? Integral battery drone!
I assume that is said in jest but just in case.HAMMER !
Probably true. I would just charge it through the USB port. Although sometimes superglue isn't as super as it seems and can be broken if it is only in spots or the parts weren't all that tight where it was glued. Something I wouldn't go into without a thorough inspection of the situationbad idea I think, too easy to damage the battery and perhaps cause a fire
I find that superglue works best when you wish it hadn't.Probably true. I would just charge it through the USB port. Although sometimes superglue isn't as super as it seems and can be broken if it is only in spots or the parts weren't all that tight where it was glued. Something I wouldn't go into without a thorough inspection of the situation
true that for sure! lolI find that superglue works best when you wish it hadn't.
So...what is the disposal solution so it is not a hazard to anyone?
I recently crashed and tried fixing my drone with super glue. But i forgot my battery was in the drone and the glue went everywhere. My battery is not coming out.
